by DJDINO on Mon Apr 25, 2016 5:58 pm
I have a M800 pnp connected to a CDL3 via a CAN cable the CAN cable is configured as per the CDL3 drawing with a resistor at each end and has a XLR connector branching off it to communicate with the ECU, when connected to this via my UTC I can connect to the M800 no problem, I connect to the dash via the ethernet cable, this works fine. I have engine temp and air temp reading fine via the M800 but cannot see these channels on the CDL3, I have followed the CDL3 instructions (installing the CDL3 to CAN ECU loom) and changed ECU CAN settings but still nothing ???
