CDL3 "changed by" operator
Postby greenamex2 on Thu Apr 21, 2016 8:27 am
Hi
Is the user conditions operator "changed by" documented anywhere?
greenamex2
Re: CDL3 "changed by" operator
Postby adrian on Tue Apr 26, 2016 6:35 pm
I don't believe there is any specific document on how that function works.
The changed by function is simply that, when ever the channel changes by the amount you have set the output will be true. Below is a bit of logging from a test I did. The blue channel is my input and the orange is the output. The condition was changed by 1.
If the input changes by the set value within the calculation period (0.04 seconds) then the output will become true. It will remain true for 1 cycle and then go false unless the channel has changed by the set value within that cycle.
Changed By.jpg (592.97 KiB) Viewed 15138 times
Postby greenamex2 on Tue Apr 26, 2016 7:06 pm
Thanks Adrian.
Any idea whether it would go true if the value change by "-1"?
greenamex2
Postby David Ferguson on Tue Apr 26, 2016 7:53 pm
As you can see from the graph above, the condition is true if the value increases or decreases by the changed amount.
Postby greenamex2 on Tue Apr 26, 2016 8:22 pm
Sorry...small monitor...didn't scroll far enough right.
Question answered, thanks.
greenamex2
Return to ADL3, SDL3 and CDL3
Users browsing this forum: No registered users and 38 guests
