Pectel SQ6 and ADL
Pectel SQ6 and ADL
Postby larryz on Fri Jan 08, 2010 12:36 pm
I have an ADL I'm connecting to a Pectel SQ6 ecu. I have it connected to the serial tx of the ecu. I can't get it to read the ecu. What should the adl communications be set to?
larryz
Re: Pectel SQ6 and ADL
Postby JamieA on Fri Jan 08, 2010 4:02 pm
If you talk to your Pi dealer, that should be able to give you their RS232 data stream fomat, then you can just add that to the ADL RS232 recieve template by clicking advanced and adding in the information as supplied.
regards
-Jamie
JamieA
Return to ADL, ADL2 and SDL
