ADL and Backlight
Wed Nov 04, 2009 2:23 am
by niceguysfinishlast
Hi all,
Does the original ADL (4Mb) come with backlight functionality on Pin 6. I've noticed the inverter module (Drawing A13) makes a reference to the ADL and ADL 2, however they both have Pin 6 showing as a Spare.
If it does, does it need the inverter to function or does it work if 12v DC is applied to Pin 6.
Many thanks
Re: ADL and Backlight
Thu Nov 12, 2009 3:50 pm
by JamieA
All ADl's (ADL, ADL2 or ADL3) can be either backlit or non backlit. Basically, there are 2 completely different LCD's, one which is for a backlit dash, one which isnt.
If it was built as a backlit dash, you just need to plug in an inverter (not required for SDL or ADL3) and it will start working. If your dash wasnt buit as a backlit model, then it wont work.
You can convert non backlit to backlit, but it is fairly involved, it has to come back here, have the display removed and have a new one added in its place that is backlit. It is a big job, and therefore isn't cheap to do.
regards
Jamie
Thu Nov 12, 2009 4:26 pm
by Martin
What would a backlit ADL do if you applied 12v to pin6?
Thu Nov 12, 2009 11:09 pm
Hi Jamie,
Thanks for taking the time to reply. I have no idea of what spec LCD the dash was built with, being an older dash, it has had a number of previous owners!
Is there any visual way of telling (screen shade/markings etc) or is the only way of finding out to plug in an inverter?
I'm on a budget so converting it, if it isn't backlit, isn't an option unfortunatly.
Thanks again
Sun Nov 15, 2009 9:00 pm
by Merlin
if you supply the serial number of the unit to one of the motec guys on here
and ask nice
they may be able to tell you
John P
