ADL and/or SDL as Standalone
Postby insomnia on Fri Dec 27, 2024 4:13 am
Hello guys,
Back on an older project, i try to use an ADL and a SDL with an ECU from MaxxECU.
We know the CAN ID for every channel we want.
The issue are:
-Can we send the MaxxECU CAN ID to the ADL or SDL Dash ?
-And if yes, how to do this ?
Any advice?
Thank you for every info....
NB: I speak from two Dashboard because we have two Vehicle...
Cheers
Francois
insomnia
Re: ADL and/or SDL as Standalone
Postby David Ferguson on Fri Dec 27, 2024 4:28 am
I would try creating your CAN template in the ADL dash manager as a test to see if you can get everything.
The one issue with the SDL is that it won't allow you to create/edit CAN templates, but you can use the ADL2 Dash Manager to create/edit CAN Comms templates then move them to the SDL Comms folder.
Postby insomnia on Fri Dec 27, 2024 5:40 am
Thank you David for your quick reply.
I will try that and let you know how i go.
Do you think this can be easier with a C125? Found one under the stairs!!
insomnia
Postby David Ferguson on Fri Dec 27, 2024 9:18 am
Well, a C125 can import a DBC file, and the MaxxECU has a DBC file found here:
https://www.maxxecu.com/files/Documenta ... l_v1.3.zip
Postby insomnia on Sat Dec 28, 2024 2:52 am
Thank you David,
Great news!
Here what i can have from MaxxECU (in the case to use the ADL)
Offset: 0
Scale: 1
Type: int16
Rate: 50hz
But i'm silly, dont know where i can put the infos into the MoTeC Dash Manager....
To much cell to fill, any advice?
Thank You David
Francois
insomnia
Return to ADL, ADL2 and SDL
