Switch input2 is not working...
Postby qorwkwkd20 on Sat Feb 17, 2024 1:39 am
Hi, I am using sdl sport dash logger.
I am stuck with input switch input2 (pin 12).
input switch 1 (pin 11) is working well. That changes the bottom display well. However, switch 2 should bottom display as well, but it is not functioning.
I have checked on the 'monitor channels' that switch 2 works. It is strange that actual display is not changed as anticipated. Is there anything that I am missing?
Cap 2024-02-16 23-18-23-461.png (40.23 KiB) Viewed 4023 times
Cap 2024-02-16 23-17-58-560.png (105.97 KiB) Viewed 4023 times
qorwkwkd20
Re: Switch input2 is not working...
Postby David Ferguson on Sat Feb 17, 2024 4:55 am
Do you have the "Previous Line Button" tick box checked in the Display window, Channels tab?
Postby qorwkwkd20 on Sat Feb 17, 2024 12:26 pm
David Ferguson wrote:Do you have the "Previous Line Button" tick box checked in the Display window, Channels tab?
Jesus christ! You are my life saver.
The tick box on the 'display' was not on.
Thank you! It resolved!
qorwkwkd20
Return to ADL, ADL2 and SDL
