Gear Indicator not working...
I have two Dash Config files.
8-14-23, the gear indicator is accurate and works.
8-22-23, the gear indicator does not work.
I need to be able to use the 8-22-23 file, naturally. What do I need to change on it to get the gear indicator to work?
I went into the Calculations > Gear Detection... The 8-14-23 shows:
Method: Sensor
Output Channel: Gear
Acceptance Delay: 0.00 seconds
Input Channel: Gear Pos Volts
0 = 2.44
1 = 1.79
2 = 1.14
3 = 0.48
4 = 4.99
5 = 4.39
6 = 3.73
7 = 0.00
8 = 3.08
9 = 0.00
The 8-22-23 config shows:
Method: Speed/RPM
Speed channel: Wheel Speed
Engine RPM channel: Engine RPM
I've gone in and changed the Method from Speed/RPM to Sensor, then select Gear for my Output Channel, and Gear Pos Volts for my Input channel. Then I input the sensor values to match...it shows the Gear Pos Volts as not assigned. I can select it, then when I hit "OK" it comes up with:
"Input channel uses the following channel:
Gear Pos Volts
This channel is not being generated. Do you want to change your selection?"
How do I fix this?
Thank you.
Method: Sensor
0 = 2.44
1 = 1.79
2 = 1.14
3 = 0.48
4 = 4.99
5 = 4.39
6 = 3.73
7 = 0.00
8 = 3.08
9 = 0.00
Method: Speed/RPM
Gear Pos Volts
How do I fix this?
Thank you.
