GPS L5 and backlight
Postby Phillippe68 on Fri May 13, 2022 4:04 am
Hello
I connected an L5 GPS to my SDL which was already configured to receive it.
I bought the car and it was missing on it.
The problem is that when the GPS is plugged in, the dashboard backlight turns off.
If I unplug it, it turns back on
I specify again that a GPS was originally connected to the car but the previous owner removed it
For the moment the test has only been done in the garage
Does anyone have an explanation ?
Thanck you for your help
Philippe
Phillippe68
Re: GPS L5 and backlight
Postby David Ferguson on Fri May 13, 2022 4:57 am
We'll it's either wiring, or dash configuration. Since you can't upload your wiring, how about you upload your dash configuration so we can see if anything is configured incorrectly.
Postby Phillippe68 on Fri May 13, 2022 5:16 am
Yes you can find it as in attachment
Norma Evo N18 2010 v4 Life Racing 2021evo2022.U16
(234.42 KiB) Downloaded 1200 times
Phillippe68
Postby David Ferguson on Fri May 13, 2022 5:29 am
I don't see anything odd with the config (I was thinking perhaps the backlight was configured to have brightness set by some channel that was affected by the GPS connection).
So that leaves wiring. Can you confirm that the GPS connector has 5V on Pin 4, and 0V on Pin 1, Pin 2 should be connected to Pin 34 on your SDL 37-pin connector, and Pin 3 should not be connected at all.
Postby Phillippe68 on Fri May 13, 2022 5:31 am
Thank you for you answer
I will check tomorrow and i will tell you
MAny thanks
Philippe
Phillippe68
Postby Phillippe68 on Sun May 15, 2022 3:18 am
Thank you for your help, it was the wiring, now it works
Philippe
Phillippe68
Return to ADL, ADL2 and SDL
