SDL UTC Problems
SDL UTC Problems
Postby jamesr156 on Mon Sep 06, 2021 10:59 am
I have a SDL with a UTC for comms. I have an older laptop that is running windows 7 that connects and so on fine with the motec. My newer laptop wont connect at all. I believe I have updated the firmware correctly.
Is there a driver or anything I need?
jamesr156
Re: SDL UTC Problems
Postby adrian on Mon Sep 06, 2021 12:53 pm
If you go to the Windows Device Manager, go to Universal Serial Bus Controllers and check that MoTeC UTC is working correctly (ie doesn't have a yellow triangle next to it).
Do you have any other MoTeC software installed on the Windows 10 laptop that wasn't on the Windows 7 machine? There may be a compatibility issue with the new versions of UTC firmware that stops it from working with the SDL but I'm not sure, I can't say I remember ever using a UTC to connect to an SDL.
Is there a reason you are connecting via UTC rather than directly with USB?
Postby jamesr156 on Mon Sep 06, 2021 12:55 pm
Thanks Adrian, I will check that out later tonight.
And no reason other than there was a UTC that was with the logger when i purchased it. Seemed like a good idea to keep using it!
jamesr156
Return to ADL, ADL2 and SDL
