cable sdl to pc
cable sdl to pc
Postby Phillippe68 on Sat Jun 19, 2021 4:50 am
Hello
I have a dash board sdl (sdl 161 b)
could you tell me what sort of cable i need to connect it on my pc
I would like to change the process of the shift light
This dash board is on a Norma M20F connected with a life racing Ecu
Many thanks for your help
Philippe
Phillippe68
Re: cable sdl to pc
Postby David Ferguson on Sat Jun 19, 2021 7:40 am
It depends on the harness. It should have a USB connection and I would expect a USB bulkhead connector of some type (possible Autosport or Lemo). You can also access that over the CAN bus with a USB-To-CAN adapter (UTC). Not common, but possible.
Re: cable sdl to pc
Postby Phillippe68 on Sat Jun 19, 2021 8:29 pm
Hi David
Thank you for your answer
the only connector i found is this one
Do i need UTC ?
Philippe
Phillippe68
Re: cable sdl to pc
Postby David Ferguson on Sun Jun 20, 2021 3:48 am
Every Norma I work on seems to have the odd-ball connectors. I think the engineers in the VdV series like to have unique cables so that only they can work on the car -- some kind of weird french job security.
That looks like the same type of connector as the UTC uses, but the gender is wrong (the car would have sockets), so It may or may not be the CAN bus.
I would contact the previous car owner and ask about connection details.
Or if you want to figure this out yourself, do a electrical contuinity check with the SDL connector and the pins of that connector to see how they are wired. Might be USB, or CAN or Ethernet to the Life Racing ECU.
Good Luck!
Re: cable sdl to pc
Postby Phillippe68 on Mon Jun 21, 2021 3:58 am
this connector is on the car and connected to the SDL
I found this on motec website
and this one
On this two cable there is 5 cables with the same color as my connector on the car
Do you think i can do the adaptator that i need
Thank you
Philippe
Phillippe68
Re: cable sdl to pc
Postby David Ferguson on Mon Jun 21, 2021 10:17 am
To avoid damage to any electronics, I would not attach anything to that connector until I knew what it was connected too. Why guess when it can be figured out.
Re: cable sdl to pc
Postby Phillippe68 on Tue Feb 01, 2022 6:40 am
Hello
After testing the car connector and the dash board connector i built a cable USB
And it works, i can communicate with the dashboard
Thank you for your help But i have somme new questions :-)
Philippe
Phillippe68
Return to ADL, ADL2 and SDL
