Looking for help with adding a brake sensor to the ADL2
I've got an ADL2 that I've inherited that's wired into a Porsche cup car. I've got some basic questions about making changes.
It's setup to read throttle position (And other items) from the CAN bus but not brake pressure (ECU doesn't supply it). I want to add that in.
There's an ABS BMW module in place (I know, weird. I didn't build this car, I just need to do some work on it). Looking at the ABS module there are brake pressure sensors there, so I think I can just tap into the lines on that.
The sensors on the line are part # 55cp09-02 and with 3 pins coming off them. Looking at the pinout on the sensor is it's a
Pin 1: ~0.5-4.5vdc varying signal
Pin 2: Ground
Pin 3: +5VDC power
So, here's my question and it may sound really basic, can I just take pin 1, tap into that wire, and then wire the split into one of the available input channels on the ADL2? I know that realistically the sensor should get it's +5v from the motec, but I don't want the ABS to have to rely on the Motec to function. I also want to be careful not to break the braking system.
Programming it is the easy part (My background is computers, I know just enough electronics to be dangerous.) and the wiring is where I'm guessing my way through.
Thank you,
Pin 2: Ground
Pin 3: +5VDC power
Thank you,
