SDL Config upload
Fri May 31, 2019 3:04 pm
by WayneMolloy
I have a SDL , when i upload a config file i get a error message afterwards, the config file does seem to upload but I'm not sure why the message pops up. the error box reads " Send Configuration" , Error reading from device memory operation failed CAN Bus error.
Can someone help
Re: SDL Config upload
Mon Jun 03, 2019 12:38 pm
by adrian
Are you connected to the Dash directly with USB or are you connected via CAN with a UTC?
Mon Jun 03, 2019 4:15 pm
by WayneMolloy
I have a UTC connected to the SDL
Mon Jun 03, 2019 6:07 pm
by adrian
Is there are reason you are using a CAN connection rather than directly connecting with USB? Does everything work once you have sent the config even though you get the error message?
Tue Jun 04, 2019 11:07 pm
by WayneMolloy
Hi Adrian
I have a M84, SLM and a LTC connected to the SDL via CAN with one diagnostic port, i only connect to ECU or SDL.
I am getting Temp and RPM from the ECU but still struggling with the lambda signal (LTC 4.9)
Wed Jun 05, 2019 9:47 am
by adrian
Can you please send me both your M84 and SDL configs, you can send them to me at
support@motec.com.au
Tue Jun 11, 2019 12:01 am
by WayneMolloy
Hi Adrian
I have sent you the requested config files, hope it is what you need, thanks
