SDL Config upload
SDL Config upload
Postby WayneMolloy on Fri May 31, 2019 3:04 pm
I have a SDL , when i upload a config file i get a error message afterwards, the config file does seem to upload but I'm not sure why the message pops up. the error box reads " Send Configuration" , Error reading from device memory operation failed CAN Bus error.
Can someone help
WayneMolloy
Re: SDL Config upload
Postby adrian on Mon Jun 03, 2019 12:38 pm
Are you connected to the Dash directly with USB or are you connected via CAN with a UTC?
Postby WayneMolloy on Mon Jun 03, 2019 4:15 pm
I have a UTC connected to the SDL
WayneMolloy
Postby adrian on Mon Jun 03, 2019 6:07 pm
Is there are reason you are using a CAN connection rather than directly connecting with USB? Does everything work once you have sent the config even though you get the error message?
Postby WayneMolloy on Tue Jun 04, 2019 11:07 pm
Hi Adrian
I have a M84, SLM and a LTC connected to the SDL via CAN with one diagnostic port, i only connect to ECU or SDL.
I am getting Temp and RPM from the ECU but still struggling with the lambda signal (LTC 4.9)
WayneMolloy
Postby adrian on Wed Jun 05, 2019 9:47 am
Can you please send me both your M84 and SDL configs, you can send them to me at support@motec.com.au
Postby WayneMolloy on Tue Jun 11, 2019 12:01 am
Hi Adrian
I have sent you the requested config files, hope it is what you need, thanks
WayneMolloy
Return to ADL, ADL2 and SDL
