Magnetic speedsensors
Postby thorstengsxr on Wed Aug 29, 2018 4:33 pm
Suzuki GSXR 1000 2017
HI Guys,
On my Suzuki I have the original magnetic 2wire speed (ABS) sensors. The sensor has 12V input and signal output. In the Yoshimura Harness I see a signal output for datalogging of both sensors (front and rear). I can see a signal between 0,7 and 1,4 Volt on the wire. But I think this is not the signal I need for my EDL2 so I putt a pulldown resistor of 100 ohm to ground. At this Moment I have no speed signal on my original dash and on the Yoshimura ECU. Is there a possible way to use the original sensor for Datalogging and the Yoshimura ecu?
Regards Thorsten
thorstengsxr
Return to ADL, ADL2 and SDL
