ADL2 and external Laptimer
Hi
I have a small problem. On my GSXR 1000 L7 I had the original display. I can’t replace the display because some configurations can only be set with the Display (TC and engine mode for example) so I decided to use my old ADL2 as a Datalogger in the back. The original display has a menu for laptimes which will updated the laptime by the flash switch. In the yoshimura harness the pin is on the logger connector. So, I connect it with the Aux 1 Output of the ADL2. For the laptime I user a GPS Mouse BL10 this works fine.
So now my question how I can send an impulse to Aux out 1 for laptime signal. My first test was a user condition. In the condition I set if Lapnumber updates set condition1. And after this I say condition1 is Auxoutput 1 but after some rounds I see that the lapnumber will change but the condition 1 is always 0 and I see no laptime in the display. Has anybody a better idear?
Regards Thorsten
Regards Thorsten
