CAN Template to send GPS data from SDL to M1 GP packages
Postby PQatPIT on Fri Jun 08, 2018 5:16 am
Hi! Looking for template(s) to send GPS Longitude and Latitude from old model SDL to M1 GP packages.
Seems that those .cc7-templates already posted in this forum do not send lat/long info at all. Here's couple .asc-files of what C185 and SDL are sending, and SDL is sending full zeroes to address 0x0680. Some data looks to be ok but mostly not.
Thanks!!
GPS_from_SDL_to_M1.asc
(22.05 KiB) Downloaded 1177 times
GPS_from_C185_to_M1.asc
(17.3 KiB) Downloaded 983 times
PQatPIT
Re: CAN Template to send GPS data from SDL to M1 GP packages
Postby adrian on Fri Jun 08, 2018 12:05 pm
I have done a bit of testing on this and can replicate your results. Unfortunately the SDL is now a number of generations old and the software is no longer under development.
Postby PQatPIT on Fri Jun 08, 2018 7:17 pm
adrian wrote:..no longer under development.
Thank You for checking this out.
Q: is it a matter of SDL software development or altering one .cc7-template? Tried to look how the template looks like with text editor but nothing I could make sense. :o
PQatPIT
Postby adrian on Tue Jun 12, 2018 10:56 am
Unfortunately it is at a firmware level (I had a bit of a play around with the templates myself), the code that transmits the CAN messages is only expecting to see 16bit numbers where as the GPS Lat/Long are 32bit and it is causing an error that stops the transmission of those channels.
Postby PQatPIT on Fri Jun 15, 2018 9:48 am
Ok. I guess this customer now has urge to update to something with colours and more screen estate.
Thanks!!
PQatPIT
Postby David Ferguson on Fri Jun 15, 2018 10:42 am
CDL3 works great with the M1 and looks just like your SDL.
Return to ADL, ADL2 and SDL
