ADL to PC Connection
Hi all,
I'm hoping to get some help here, I have ADL display which I'm trying to connect to the laptop to change the configuration for Pectel E2 ECU (not even sure if this is possible).
I'm using USB to Serial converter, which I'm using with different program without any issues coming to Com1, but I'm not able to see or upload the ADL setup.
I have used pin 2 and 3 in the 9 pin connector connected to pin 79 and 78 (tried to swap them as well) and also common ground from the ADL with the Pin 5 on the Serial Connector.
I have setup the Com port to match the Laptop Baudrate 9600, No Flow control, I get only the following message:
Timeout Waiting for header
it is the same as not connected anything to the serial port, I have tried different configuration, but still no luck at all.
My laptop is Win8 64, I have found information it is not working with ADL Dash manager, only with ADL2 Dash Manager:
If you are using any 64 bit version of Windows 7 or 8, you must download ADL2 and UTC 64 bit USB drivers from software/latestreleases for the communications to work between your laptop and the device.
but I get exactly same message as on ADL Dash Manager.
Would you guys be able to advise, what I'm doing wrong?
Would you know, if it is possible to connect the ADL to Pectel E2?
Thank you in advance for any advice
