Showing Fuel Used - Ford ECU
Hello all
I am very new to the motec world. We are working on a 12 Ford Mustang with the factory ECU and an SDL dash logger. The system was set up to monitor many aspects of the suspension and more, but I am looking for monitoring the fuel used in order to calculate when we need pit stops for endurance racing. The car does have an aftermarket fuel cell and a sending unit, but it seems less than the most accurate way to go.
It seems with modern cars they monitor the fuel usage to calculate MPG, miles to empty and the like so I imagine the ECU is looking at consumption. I would imagine you can pull this off the OBDII port information. All of this is WAY over my head and I'm trying to figure this out. Any dumbed down advise would be greatly appreciated. I'm going through videos and the manual but not getting anywhere.
Thank you so much.
Jake
Thank you so much.
Jake
