g force sensors for ADL
Postby Griffo on Thu Mar 09, 2017 9:37 pm
Hi can I use a Subaru YAW sensor as G sensor for track mapping
Griffo
Re: g force sensors for ADL
Postby Stephen Dean on Tue Mar 14, 2017 4:21 pm
Hi Griffo,
A yaw sensor will measure rotational speed, and is used for calculating slip angles (typical road car usage is in vehicle stability systems). As you can have a vehicle experiencing cornering forces without inducing a yaw angle (steady state cornering without slip at either end of the vehicle), this is not going to be usable for the generation of a track map.
If there is G force being output from the sensor, then this could be logged and used for track mapping.
Return to ADL, ADL2 and SDL
