ADL on M800
ADL on M800
Postby cotje on Sun Nov 22, 2015 7:35 am
After getting my M800 up-and-running with SKM and SLM I'm orienting towards an ADL dash. I only want to display all the possible data as seen in the M800 ECU manager like, ET/AT/EGT/LA1/RPM/MAP/KNOCK and ground speed (GPS?). I've no need for extra input/outputs or logging (standard M800 logging is just fine).
Question is: would the older ADL suit my needs? I've read some challenges with connecting a GPS
Thanks!
cotje
Re: ADL on M800
Postby David Ferguson on Sun Nov 22, 2015 8:23 am
The only thing the original ADL won't do relative to GPS is GPS-based lap timing. You can still receive a serial (or CAN async serial) stream and capture the GPS speed. Our simply fit a wheel speed sensor to either your M800 or ADL.
Re: ADL on M800
Postby cotje on Sun Nov 22, 2015 8:51 pm
Perfect, thanks!
Just need the speed indication.
cotje
Return to ADL, ADL2 and SDL
