SDL1 - DIG IN as a switched input
Hi Guys,
How can I use a DIG IN as a switched input?
Can I gnd the pin to activate?
I want to assign user alarm 1 to it which will activate an ouput to the ECU pending specific conditions.
Example:
DIG IN 1 = gnd
EGT = x
FP = x
OIL pressure = x
RPM = x
If all above requirements met, activate AUX output x (to ECU). ECU then requires:
AFR = x
AIR TEMP = x
activate OUTPUT -> x, increase RPM limit, increase boost, retard ign timing.
Advice appreciated.
Example:
DIG IN 1 = gnd
EGT = x
FP = x
OIL pressure = x
RPM = x
AFR = x
AIR TEMP = x
Advice appreciated.
