lap gain/loss vs best lap of session?
Postby mikey on Wed Mar 19, 2014 9:11 am
Hi guys,
New to MoTeC, I have an ADL w/M800 ECU. I see running lap gain/loss calculation is by default versus a reference lap that is input to the dash logger prior to going on track. My question is can I set up lap gain/loss to reference the current fastest lap of the ongoing on-track session instead? The logger records lap minimum time so it would seem it should be possible to do a maths channel and display running lap gain/loss against that?
Appreciate any help, I'm slowly learning how to use MoTeC. My only other experience with data is AIM EVO4 and steering wheel display.
Cheers,
Mikey
mikey
Re: lap gain/loss vs best lap of session?
Postby mikey on Sun Mar 23, 2014 3:44 pm
In the absence of any other suggestions, I've created a maths channel to perform this equation:
(predicted lap time) - (min lap time) = General Purpose Time 1
I then set the display to show GP Time1 in the left display #. I'm assuming "min lap time" is updated in the logger anytime you best a lap time within that logging session. Thus each time I'm on track, the above equation will reflect a negative number if my predicted lap is faster than prior min lap time.
Unfortunately it will be another 6 weeks before I get to try this out. If anybody can advise if I'm on track (pun intended!), I'd appreciate it.
Cheers,
Mike
mikey
Return to ADL, ADL2 and SDL
