dash manager questions for ADL and shift light programming
Hi all,
I'm new to MoTeC, my car has an original ADL and billet shift light (4 input). Also running an M800 ECU. The car is a 2004 pro formula mazda.
I'm slowly learning how to program the dash, but can't seem to figure out how to setup some things. Trying to make my shift lights flash rapidly, maybe 5 or 10hz, at my desired shift rpm. The config file that was in the car when I got it simply turns each of the aux1 through aux4 outputs on solid at whatever rpm I set.
I see there are some pre-set frequency channels, but I can't seem to figure out how to tell what frequency they are each for? I see eight general purpose channels for frequency, but they all look the same. I also ran across one section during simulate mode that might be implying 22hz is the slowest possible rate, which would be too fast for the intended effect.
Does it have anything to do with remote control channels? Do I need to set it up that way?
Can anybody help?
Thanks,
Mike
Can anybody help?
Thanks,
Mike
