SDL and 4x EGT alert options
Postby bazeng on Thu Nov 01, 2012 9:17 pm
Hi All,
I will.be running a 4 channel EGT amp to the SDL.
It will be used on a 4 cylinder monitoring each exhaust runner.
What can I do on the SDL to monitor any possible issues that may occur with the leaning out of one cylinder?
My thoughts are:
1. Tune the car, log the EGTs
2. Use log to determine normal egt temps and setup alarms that will trigger if any temps go above the logged values using rpm / egt temp as axis.
Is this achievable?
Are there any other options?
bazeng
Re: SDL and 4x EGT alert options
Postby Holmz on Fri Nov 02, 2012 2:09 am
Are you looking for the whole engine to be out?
Or one cylinder to be different than the others?
Postby bazeng on Fri Nov 02, 2012 4:01 am
Either.
Anything that will put the engine at risk.
Especially with this e85 injector blocking goo that i see online and on friends vehicles.
bazeng
Postby bazeng on Fri Nov 02, 2012 4:03 am
I will be linking the alarm to an output which will trigger the ecu to go into either boost cut or ignition / fuel cut.
bazeng
Postby Holmz on Sat Nov 03, 2012 11:17 am
bazeng wrote:Either.
Then you may want to compare the 4 EGTs and when one deviates higher then the rest, then that may give you insight into lower fuel flow on that injector.
Postby bazeng on Sun Nov 04, 2012 12:36 am
Is that achievable in the software?
If the difference between all 4 signals is greater than a certain percentage, activate output x....
bazeng
Return to ADL, ADL2 and SDL
