sdl in windows7
sdl in windows7
Postby busaman on Sat Jun 30, 2012 6:11 am
i can open my sdl config on my laptop with xp but it wont open with windows7 version 1.60.80.0 on my pc it says file version incompatible
busaman
Re: sdl in windows7
Postby JamieA on Mon Jul 02, 2012 10:35 am
I have windows 7 64 bit, and SDL manager works without any issues, so your problem is not to do with windows 7 specifically.
make sure that you have run this executable on your windows 7 machine:
http://www.motec.com.au/filedownload.ph ... docid=3576
Also, ensure that you have the same version on both laptops.
Finally, I recommend tha tyou try to open the config by starting up dash manager, and using the File/Open option in the software rathern than double clicking on the config.
regards,
Jamie
JamieA
Re: sdl in windows7
Postby busaman on Tue Jul 10, 2012 6:47 am
hi jamie i have tried everything and this is what i get.
dave
busaman
Re: sdl in windows7
Postby JamieA on Tue Jul 10, 2012 12:12 pm
are you installing the program as administrator. You need to do this with windows7
to do this, download the install file to somewhere you have access to. then right click on the setup.exe file, and tell it to run as adminstrator.
that should fix the problem...
regards,
Jamie
JamieA
Re: sdl in windows7
Postby busaman on Wed Jul 11, 2012 7:53 am
no the result was the same as the first.
busaman
Re: sdl in windows7
Postby busaman on Wed Jul 11, 2012 5:00 pm
hi jamie this is the config see if your program can open it,
dave.
daves race dash.U16
(234.56 KiB) Downloaded 1738 times
busaman
Re: sdl in windows7
Postby JamieA on Mon Jul 16, 2012 10:35 am
Im sorry, I didnt understand the problem before...
Now I understand the issue, I have downloaded your file..
If you open your U16 file with a hex editor, you will find that although it is exactly the correct size, it contains nothing but zero's thoughout the whole file..
where did you get the file from?? you will need to re-retrieve the file.
regards
-Jamie
JamieA
Re: sdl in windows7
Postby busaman on Mon Jul 16, 2012 4:55 pm
hi jamie the file is from the dash on my race bike i will download again and report.
dave.
busaman
Re: sdl in windows7
Postby busaman on Mon Jul 16, 2012 5:02 pm
i dont know what happened in the upload but i also checked tho original file in hex editor it was ok but as you say the uploaded one wasnt i upladed it again with the same result something happens in the upload process do you have an email i can send it to.
dave
busaman
Re: sdl in windows7
Postby JamieA on Mon Jul 16, 2012 10:05 pm
JamieA
Return to ADL, ADL2 and SDL
