SDL Air Temp reading to low.
I have an Autronic SMC connected to a SDL.
Everything works fine except for the engines Air Temp is reading way to low.
The air temp shows correct in the Autronic software as live data.
However the air temp displayed on the SDL or viewed in i2 is alot cooler.
EG yesterday the customer ran the boat to 118 MPH, in the data log downloaded from the ECU the air temp was around 36 to 38 degrees and peaked at 42 degrees celcius at 14 psi, the majority of the log the air temp is around the 34 degrees mark.
However the air temp in i2 peaks at only 4 or 5 degrees celcius.
Engine idling on the hose yesterday, the air temp was 30 degrees and the dash showed 2.4 degrees celcius.
The engine air temp data is sent to the SDL via RS 232 from the SMC.
We ran this same SDL with the old boat that had an Autronic SM4 and never had any issues with the air temp readings.
Any ideas, anybody.
Dave.
Any ideas, anybody.
Dave.
