SDL dash to LIFE F88 ECU
Sun Jan 08, 2012 5:37 am
by busaman
Does any one know the settings or is there a template for setting up comms between SDL dash to LIFE F88 ECU its all wired in just how do i make them talk to each other.
Re: SDL dash to LIFE F88 ECU
Mon Jan 09, 2012 2:15 pm
by JamieA
I must say that I have never seen a Life ECU here in Australia.
Ill ask the MoTec Europe guys if they have any info on this type of ECU.
regards,
Jamie
Mon Jan 09, 2012 7:04 pm
by busaman
ok thanks jamie it will be the same as pectel sq6 and syvecs s8 it is effectivly the same ecu.
Tue Jan 10, 2012 7:32 am
by stevieturbo
Have you tried asking Pat/Syvecs, or over on the Syvecs forum ?
Tue Jan 10, 2012 9:52 am
by busaman
not as yet i only registered today.
Tue Jan 10, 2012 9:45 pm
by AlanB
The attached ADL2 file has a set of LIFE F88 templates in it. You can save them from within ADL2 Manager then move them to the SDL comms directory to make them available from within SDL Manager.
As the SDL only has 6 CAN slots, you will have to pick and choose which templates you use as there are more than 6.
Wed Jan 11, 2012 2:47 am
by busaman
thank you very much alan.
Tue Jan 17, 2012 6:05 am
by busaman
AlanB wrote:The attached ADL2 file has a set of LIFE F88 templates in it. You can save them from within ADL2 Manager then move them to the SDL comms directory to make them available from within SDL Manager.
alan is there a particular way to save and install them, i can see them in adl manager but the ones in sdl manager seem to be a different file type.and dont show up when i open sdl manager.
dave
