Signal ground for sensors
Hello all,
I tend to use a few different industrial sensors that have the standard, Power, Signal & Ground wires. Frequently, however, they require the use of a Sensor or Signal ground. Is there a pin that is recommended for this use, or is it the standard channel ground that should be utilized?
I find that the channel grounds are common to the power ground in the harness. However, I would like to know if there is a pin specific to this type of ground that you recommend.
Thanks.
Peter
Thanks.
Peter
