Downshift light using SLM
Looked at the pdf file for the SLM.
I have an ACL but no MoTeC ECU.
I want to set up the ACL so that when the brakes are on and I am decelerating over a certain amount, it then blinks an SLM with a downshift colour.
Probably this would be at certain speeds related to RPM in the next gear down.
So I would be having the ACL look at speed, deceleration and/or brake pressure.
And maybe RPM, so that if the RPM is below some amount (i.e. 4k) then the light does not blink, or a switched input for "track mode".
Is there a beginner 101 on this?
