SDL Logging Data From M800
Sun Jun 20, 2010 6:50 am
by killerbee
I am trying to log oil pressure onto the SDl from the M800. The units for the M800 are psi and trying to display psi on the SDL. However, the numbers do not match, logged or displayed real time. What am I missing ?
Re: SDL Logging Data From M800
Sun Jun 20, 2010 3:34 pm
by Ellis7
You have to set up all sensors in the M800 as metric (kPa etc) if you want to CAN them to the SDL/ADL. Otherwise, as you can see, you need to do some scaling. Once they are in the SDL you can change the outputs to read psi in the dash display setup.
Mon Jun 21, 2010 5:03 am
by killerbee
Ellis7,
Thank you very much for the response.
Brian
