SDL Logging Data From M800
Postby killerbee on Sun Jun 20, 2010 6:50 am
I am trying to log oil pressure onto the SDl from the M800. The units for the M800 are psi and trying to display psi on the SDL. However, the numbers do not match, logged or displayed real time. What am I missing ?
killerbee
Re: SDL Logging Data From M800
Postby Ellis7 on Sun Jun 20, 2010 3:34 pm
You have to set up all sensors in the M800 as metric (kPa etc) if you want to CAN them to the SDL/ADL. Otherwise, as you can see, you need to do some scaling. Once they are in the SDL you can change the outputs to read psi in the dash display setup.
Cheers
Ellis7
Postby killerbee on Mon Jun 21, 2010 5:03 am
Ellis7,
Thank you very much for the response.
Brian
killerbee
Return to ADL, ADL2 and SDL
