Data playback on dash
Postby neillsun on Fri Jun 11, 2010 3:08 am
Is it - or could it - be possible to play data back through the Simulate option of Dash Manager to see the actual results on the dash??
I need to go through some data, viewing exactly what the dash displays.
Please help!
neillsun
Re: Data playback on dash
Postby JamieA on Mon Jul 12, 2010 7:39 pm
you cannot replay a section of logged data, but you can use the simulate function to put your dash into the same state that you wish to check.
so go into simulate, set the required values, and the dash should act as it would normally in that situation.
regards
Jamie
JamieA
Return to ADL, ADL2 and SDL
