ADL2 to M130 Custom CAN Message (need help)
Re: ADL2 to M130 Custom CAN Message (need help)
Postby David Ferguson on Thu May 10, 2018 2:56 am
Good to hear!
Postby mr2andy on Thu May 10, 2018 5:58 am
By the way David,
Is there anywhere in M1 Tune which I can look at the raw data on CAN BUS?
Reason I asked is that the 4 wheels speed sensor is coming into M130 from the ADL2 through CAN but I'm not sure what data is ADL2 sending? Do you think it's the voltage/frequency data which I need to convert to mph in M130 or it's the converted/calculated data just like I'm seeing it on the ADL2 display which is currently in mph?
mr2andy
Postby David Ferguson on Thu May 10, 2018 9:21 am
Forum went down when I tried to send the first version.... Argh....
There is no "CAN Capture" feature in M1, however, there is a 'CAN Inspector' utility (available as part of Utilities v1.17 at the bottom of this page: http://www.motec.com.au/software/latestreleases/ ) that will work connected to your M1 through the Ethernet connection.
But you may not need this, since if you look at the Wheel Speed Templates (click the advanced button), then the Transmitted Channels tab, then "Change.." one of the channels. You will see it sends the speed in 0.1 km/h units. You could scale this in the template, but I would just change the "Wheel Speed Front Left Sensor Scale" value so that the GPS speed matched the reported Wheel Speed. The same scale number should work for all tires of the same circumference (so might be different for front & rear depending on your car).
Return to ADL, ADL2 and SDL
