M800 with Denso IAT sensor
Postby SuperNutz on Fri Jan 29, 2010 11:27 am
Is it posible to use Denso iat and water temp sensor? if i have the sensor resistance value ?
Any one know Motec internal resistor for iat and water temp value?
SuperNutz
Re: M800 with Denso IAT sensor
Postby IJ. on Fri Jan 29, 2010 3:35 pm
There are Macro's for the delco sensors in Adjust>Sensor setup>Input setup.
IJ.
Postby RossB on Wed Feb 03, 2010 9:15 am
You will need to use a custom calibration for a denso sensor. Do you have resistance vs temperature values for the sensor?
The M800 AT inputs have 1000 ohm pull up to 5V and 100K ohm pull down to 0V.
Postby SuperNutz on Wed Feb 03, 2010 11:04 pm
Thank Ross
i have calibrate resistance vs temp. pull up resistor values is all i need for voltage curve
SuperNutz
Postby Polux RSV on Sun Feb 07, 2010 8:25 pm
Taking the 100k pull-down in account in your calculations is important at low temps, lower than 0°. Else, it will not make a significant difference.
Angelo
Polux RSV
Postby SuperNutz on Tue Feb 09, 2010 12:10 pm
I doubt it would be anywhere near 0 degree where i live, but thank for the info
SuperNutz
