upgrading software on m800
Postby zxrjohn14 on Thu Jan 21, 2010 7:52 am
i have version 3.50 on the ecu and wondered what are the advantages to upgrading to the 3.52?
i plugged everything in to upgrade but a warning come up saying about this can cause problems.
has anyone encountered any problems?
is it advisable to stick with what i've got/know?
many thanks for any help
john
zxrjohn14
Re: upgrading software on m800
Postby ejenner on Mon Feb 01, 2010 8:46 pm
Often best to stick with what you know. However, if the new features are worth having then upgrade. I was using version 2.3 because my rolling road recommended it for simplicity - at the time I was only doing very simple ignition timing control. On advice of Motec I upgraded to 3.5.1 but now doing the full works so was worth having something a bit better than before. But the difference between 2.3 and 3.5.1 are massive. Things like REF/SYNC capture are very valuable tools and not available in the earlier version.
These are the updates: Extended data entry range on Input Setup Warning Hi/Lo values, Axis Setup tables, Lambda Calibration tables, Timer Maximums and CAN funtion Address ranges.
Probably not worth upgrading unless you want any of those features in particular.
ejenner
Users browsing this forum: Majestic-12 [Bot] and 10 guests
