Bosch Motorsport Ignition Coil
Hello guy's!
I have a question about a Bosch Motorsport Ignition Coil with an integrated Ignition Module
*Single Fire Coil P100-T (http://www.bosch-motorsport.de/pdf/comp ... P100_T.pdf)
From the data sheet I know that the coil needs a ignition signal in the range of 10mA to 20mA. From a Motec Data Sheet from the downloadsection I know that Denso also designed such a Ignition Coil with integrated Ignition Module, so this system should work with the M800. But I was not able to find a data sheet for the denso coil :/
My problem is that i don't know what my Motec M800 provides at the ignition output. I think i read in a data sheet from Motec that the M800 provides a current from 1A to a maximum of 3A but I'm not sure.
Many thanks in advance for your help!
Best Regards
Luke
Best Regards
Luke
