Motec m800 on one cylinder four stroke quad
Tue Jan 05, 2010 8:35 pm
by aladidi
hey guys .. am testing m800 on Yamaha Raptor 700 and i want to know if there is any way to setup the unit to control four stroke/one cylinder motor
its running now on 2 stroke mode but it knocks a lot .. any help would be appreciated
Re: Motec m800 on one cylinder four stroke quad
Wed Jan 13, 2010 9:24 pm
by RossB
The ECU can control a single cylinder four stroke provided that it has the correct sensors for ref and sync, what sensors and trigger are fitted to the engine.
Thu Feb 18, 2010 10:45 am
by dA_RoB
Hi aladidi!
We are using the Motec M800 on our 450cc 4-Stroke 1 cylinder Rotax engine without any problems. In the past couple of years we used it on Rotax 650cc engines also from rotax (built for bmw) and there were also no problems. if you need some help with the settings just ask.
like RossB said, make sure you have set up the sensors for ref(crankshaft) and sync(camshaft) correctly.
greets
RoB
