AT calibration curve help
Postby M800 on Sun Aug 10, 2008 8:57 pm
Hi all,
On the M800, I'm wanting to use the stock engine temperature sensor as it has 3 pins and serves the in-dash temp gauge.
So I have developed a calibration curve (resistance vs temp C) for the sensor.
However in the custom sensor setup, for the AT, the fields are volts and Temp. I can use V=IR to establish V but I need to know the current ..... or am I going about setting up the calibration table incorrectly?
Also can we use another AT for the Air temp apart from AT1 ?
Thanks for the help
Bazz
M800
Re: AT calibration curve help
Postby RossB on Mon Aug 11, 2008 2:16 pm
Hi Bazz,
To work out your voltage from resistance you need to take in to account the pull up resistor (1000 ohms on M800) supply voltage (5V) and the sensor resistance at a particular temperature. The calculation is:
V=Supply V x (R/(Pull-up+R)).
I have attached a spread sheet which I use for this to make it easier, just fill in the pink cells and you will have your calibration in volts.
Volts from resistance.xls
(25 KiB) Downloaded 2208 times
Postby M800 on Mon Aug 11, 2008 4:30 pm
Cheers Ross,
We are back on the dyno again on Wednesday and this is one less thing that Lee has to worry about 8-)
It was the pull up value I was needing, so it's all good now, thanks
Hopefully the timing belt will stay on this time :roll:
M800
Postby John Reed on Mon Aug 11, 2008 5:08 pm
Ross's answer surpassed mine over on EFI101 with that spreadsheet, that will come in handy for sure!
John Reed
Motec Sales/Install/Tuning/Support
johnreedracing@gmail.com
John Reed
Postby RossB on Mon Aug 11, 2008 5:25 pm
Forgot to say, you can use any AT Input for Air Temp. We normally use AT1 and AT2 for Air Temp and Engine Temp and if you were to upgrade a file from an M4 or M48 this is where they would be asigned. I would say that it is probably a good idea to stick to this convention but it is up to you.
Postby M800 on Mon Aug 11, 2008 5:55 pm
Thanks John and Ross, you both had the answer :D
John, I had actually used your hint successfully, but as you say the spreadsheet is a handy item to have available for future use.
Cheers Guys
M800
