I need a control circuit
Postby Bolarbag on Sat Aug 09, 2008 4:59 am
I currently have an Electric Water pump that I supply 12V to via a relay, the relay controlled via an output from the motec
I want to input a control circuit, having the water pump on half its output until a certain water temp is reached, probably around 75-80deg, then have the WP on full as before
Any ideas?
A simplistic relay circuit would be to input a 2nd relay circuit, having the motec control relay(1) - (half output) -from engine start obtained via a 6ohm 100W resistor in series with the 12V supply circuit
Having Relay(2) controlled via the motec switching on from say 75-80deg providing the pump with the full output (12V/6-7A)on the 2nd circuit and switching relay(1) off, when relay(2) is energised
The only problem I can see here is I'll be using 2outputs - of which I'm lacking already and the fact my voltage output is defined by the hardware(resistor) that I install, I'm not entirely sure yet whether half the output will be sufficient as I still have to test
No thermostat is being used currently, the aim of this circuit is to allow the engine to heat up but to make sure it does not overshoot i.e not overheat before the pump can bring temps under control
I suppose for test purposes, I could use a pot to find out exactly how much resistance and therefore voltage is needed before the temps overshoot
I do not want to have the Water pump completely off until I get to temp as I've been told that heat spots in the engine can appear very quickly with no flow
I also intend wiring a third circuit to the pump with a manual switch so I can have the WP on whilst I'm cooling my engine trackside with ign off
Bolarbag
Re: I need a control circuit
Postby GWRMOTORSPORT on Sat Aug 09, 2008 5:13 am
Hi Bolarbag
here in the UK we use solid state relays that can switch at frequencies and duty cycles
to give a wide control of water pump speed using 1 output from the ECU,
ie
stage 1 at first ECU power up the pump is run at full speed for 3 seconds
stage 2 water temp is controlled by the speed of the water pump, 2 axis table in ecu, et & ground speed, with
a minimum speed to prevent hot spots
stage 3 the ECU is wired for power hold and the water pump is run after engine shut down to reduce heat soak
hope this helps
Steve
GWR Motorsport
GWRMOTORSPORT
Postby figgie on Sat Aug 09, 2008 7:48 am
As stated by GWMOTORSPORTS
this is a PWM circuit with adjustable base frequency and then duty cycle dependant on the input.
The tricky part is the input based duty cycle control.
Luckily for us, the MoTeC has it built in! :D
Using a solid state relay
http://www.hongfa.com/products/chp.php? ... sp_type=02
then on the Mx00 series ECU.
Assign PWM Idle Control (#2) to one of the aux outputs.
Then assign the output mode according to how you wired it (Switch to Ground or Switch to battery).
On the table assign Engine Temprature as a X axis and then (as an example)
0-60 degree C = 50
61-100 degree C =100
Done!
It will PWM the solid state relay and basically do speed control on the water pump for you based on temprature!
figgie
Postby SprinterTRD on Sat Aug 09, 2008 9:16 pm
Hella make a solid state relay that fits into a standard relay socket
Postby Martin on Sun Aug 10, 2008 9:59 pm
Hi Sprinter,
Have you got a Part # or any link to this product?
Postby SprinterTRD on Mon Aug 11, 2008 3:05 pm
H41773001
Postby Bolarbag on Mon Aug 11, 2008 7:32 pm
Many thanks guys, exactly what I was looking for
That should teach me to consult with my hardware guys before trying to come up with a solution;)
Bolarbag
