driveshaft rpm traction control
Id like to set up a a control circuit that will look at a target driveshaft rpm vs. time.
If the driveshaft rpm goes above the target driveshaft rpm at a certain time I would like a rpm limiter with randomizer to go into effect until it brings it back down to the target driveshaft rpm.
Any help would be appreciated.
4 pulse trigger is being used.
Id like for this to be recorded in the data so I can view it in conjunction with timer 1 for setting up the control curve.
Im thinking the slip program under traction control but just cant get it worked out.
