Mercury Marine 8.1Lit V8 running PCM Module
Tue Nov 24, 2009 8:02 am
by toby
Does anyone have experience of this engine running an M800/880? I am looking for a base map and if available, an adaptor loom from the stock loom to M800/880 or even a mating plug for the stock loom from which to make an adaptor. Any help would be appreciated.
Re: Mercury Marine 8.1Lit V8 running PCM Module
Wed Nov 25, 2009 5:34 am
by bx7
you want to make an adapter for the original connector of the engine ECU?
Re: Mercury Marine 9.1Lit V8 running PCM Module
Wed Nov 25, 2009 6:55 am
by toby
I want to make an adaptor from the original loom to MoTeC M800/880. The engine is a Mercury 1075 converted for racing with 2xLisholm superchargers making 930HP. The original ECU is a PCM module. Sorry I was not clear in my earlier post.
Wed Nov 25, 2009 9:46 pm
by bx7
Ok, what need would be the original wiring of your PCM. what do you have?
Wed Nov 25, 2009 10:28 pm
by bx7
this is an adapter for a rally car
Thu Nov 26, 2009 12:42 am
by toby
Its the mating plug and base map I am looking for.
