DBW throttle response
Postby 48DZI on Mon Nov 23, 2009 8:36 am
The throttle is too aggressive, will changing the P,I,D parameters help here
48DZI
Re: DBW throttle response
Postby Dragon on Mon Nov 23, 2009 11:21 am
What do you mean by aggressive?
If the DBW throttle was characterized by Motec, I do not suggest you change the PID.
Changing the translation table may be more appropriate.
Dragon
Postby Martin on Mon Nov 23, 2009 3:33 pm
Dont touch the PID
If the DBW unit matches the PID settings as characterized then you leave them alone.
THe position translation table is there for you to play around with to make the response more sluggish or whatever you would like to get out of the setup.
Postby 48DZI on Wed Nov 25, 2009 2:12 am
Thanks Guys,
Here are the original PID settings
P=100
I=50
D=140
Period =2
Deadband=0.3
Feed Forward=30
I will change the Position Translation as advised and see how it responds as the curve is quiet steep from around 42% TPD upto 90%
48DZI
Users browsing this forum: No registered users and 28 guests
