Hi all,
I just notice with i2 that while rpm goes up, boost decreases a bit (-15 kPa) because boost valve duty cycle slowly increases from normal position 50 to 54.
Do you think I need some Integral then? Now is 0.00.
DarrenR wrote:Hi,
Yes a small amount of integral gain should help trim out this small error.
Having a relatively small error, you should set the integral clamps fairly tight also to stop windup.
Testing will show the amounts required.
Users browsing this forum: No registered users and 69 guests
