Hey guys,
Just a quick one, i am trying to use an M880 as a data logger for a drag car, (carby engine), have all of my pressure/temp sensors working but cannot get the wheel speeds to work on the digi 1 & 2 channels. do they require a pull up resistor? which pins does it go across if so?
how do you calibrate the pulses per K/m on an m880? I am used to setting ADL/ACL but never used ECU to log this sort of thing before.
thanks for any help!
