Best Idle Air Control Valve (IAC) for M400
Tue Nov 03, 2009 1:58 pm
by mr2andy
I would like to know which 4 wires IAC valve will work the best with Motec M400.
Cheers
Andy
Re: Best Idle Air Control Valve (IAC) for M400
Wed Nov 18, 2009 12:57 pm
by OmarK
Hi there,
Can you provide more details about your particular application and the engine you are using?
Regards,
Fri Nov 20, 2009 1:53 am
by mr2andy
Omar,
I went out and bought a haltech branded IAC and IAC housing. I believe the IAC is actually a 4 wires not sure if it's a bypolar or unipolar IAC. I believe it's a GM/DElco style IAC.
Will be installing the M400 on a 3SGTE MR2 with custom instake manifold.
Fri Nov 27, 2009 9:53 am
by RossB
If it is a 4 wire valve it sounds like it is a stepper motor, this is not the best thing to use, I would use a PWM controlled valve. A 2 wire one from a Ford would work ok, much better than stepper motor idle control.
Tue Dec 15, 2009 2:06 am
by mr2andy
Thanks for the reply Ross.. Can you elaborate a little more on this?
I haven't drop in the idle air control motor cause I'm thinking maybe I can get by without using one.
Can you tell me more about the 2 wire PMW IAC please?
Cheers
