Upgrade -- Now won't start (!??!) (HELP ASAP PLZ)
Last night I connected the unit to the laptop (first time). The following message was displayed:
An ECU with an old version of the ECU firmware has been detected. Communications be established until the ECU firmware is upgraded. ECU version = V3.41 Latest version v3.52F.
Would you like to upgrade now?
I pressed 'yes' and it said 'Enter ECU password'.
I pressed 'cancel' and then it said
The ECU has an incompatible firmware version. This version of ECU manager cannot be used. Disconnect the ECU or abort.
I tried to find version 3.4 on the Motec site but it was not there (even in old files). If I had had that I would have been able to connect directly and have access.
Now, I put on version 2.3 as it was the only one I was able to and now the car won't start! The car was starting before but now it seems the file is wiped and I can not open the file or switch the car on!!!
What has happened here? Why would this be the case? Where is version 3.4 so I can put that in my laptop and at least try and open the earlier file? Or is there another way?
Would really appeciate a hand here.
Thanks.
Thanks.
