Motec with 2GRFE In to an SW20 MR2
Hello all, I have been doing some extensive research into swapping a newer V6 into my track MR2, specifically 2GRFE with dual vvti
http://en.wikipedia.org/wiki/Toyota_GR_engine
In stock form
http://marclabranche.com/V6MR2/dyno.jpg
I want to use a motec m600 for my track car over the stock ecu for obvious reasons. The 2GR can physically bolt into an MR2, a few have already completed the swap with the stock ecu.
I was planning on running the motor with speed destiny.
Now my question is regarding wiring. I am really looking for some guidance, running mostly Motec branded sensors for all the basic inputs? Or wire in the OEM ones? How exactly does the 4 vvti cams get wired in. Also the DBW?
Basically i will need to wire in, IAT, Coolant Temp, MAT Sensor, VVTi controls, Igniton, injectors, and various gauge outputs?
thanks for you help, this will be my first wiring project, in the past i have relied on plug and play solutions
-Mark
In stock form
-Mark
