RX8 Generator (Alternator)
Postby Martin on Fri Oct 02, 2009 9:16 pm
Not sure where to post this....
The RX8 Has got a Genrator that is discibed as a regulatorless generator with built in power transistor in their workshop manual.
There are 2 wires on the generator to the ECU
1. ALTT V (Input voltage from generator) units = V
2. ALTF (Generator field coil control signal) units = %
This is what I can find the manual and it seems controlable with an M800. Any advice from anybody that has tried it on a RX8?
Thanks M
Re: RX8 Generator (Alternator)
Postby ElectronSpeed on Fri Oct 02, 2009 10:02 pm
I have not used the RX-8 alternator you mention (despite working on RX-8s). I believe that most people here backdate to a RX-7 piece with an internal regulator.
The externally regulated ones I have used can draw multiple amps through the field. Choose your controller carefully.
Eric Schieb
Electron Speed
ElectronSpeed
Users browsing this forum: Google [Bot] and 7 guests
