Mazda RX8
Im busy with a street RX8, everyting stock except a supercharger fitted with intercooler.
APV (Auxiliary port valve)
1.Is the servo upgrade needed to drive the APV?
OMP
2. Is it advisable to run a OMP on a charged RX8? Is the pumps flow suffiecient?
3. How is the oil flow calculated for a certain application
4. In the Motec OMP setup.........
127 : Mazda RX8 APV Servo
Controls the Mazda RX8 Auxiliary Port Valve.
Aux 5,6 or 7 only, also uses next output (requires high side drive)
Mazda RX8 OMP:
The table specifies the desired Oil Metering Pump position.
The table units are Steps.
The duty for the output (normally "Aux Out5 Duty Cycle") is the actual
position (in steps), the duty for the next output (normally "Aux Out6
Duty Cycle") is the aim position (steps).
Can somebody please shed some more light on what the underlined part means? How could the outputs duty refer to the aim position and the output duty of the other the actual position?
Has anybody ever done a OEM setup but with a charger like this?
M
OMP
Mazda RX8 OMP:
M
