Page 1 of 2
Wiring help! Motec CAN female connector - Deltron 716-0-0501
PostPosted: Wed Sep 23, 2009 2:02 pm
by mr2andy
Guys,
I bought the DEM 724-0501 (Non Latching) connector from Motec and have no idea how to wire it up with the wiring harness. Can anyone help?
Andy
Re: Wiring help! Motec CAN female connector - Deltron 716-0-0501
PostPosted: Wed Sep 23, 2009 3:38 pm
by MarkMc
Hi Andy,
The wiring is on all the ECU drawings for the M400, M600 and M800 but for the record the pin out is:
1: 0v comms (ECU B14)
3: 8v (ECU A13)
4: CAN Lo (ECU B24)
5: CAN Hi (ECU B23)
PostPosted: Thu Sep 24, 2009 12:22 am
by mr2andy
Thanks Mark,
Which pin is no1, no2, ... on the plugs?
By the way, do I crimp the wires directly to the pin on the connector or soldered them on and wire heat shrink it?
Andy
PostPosted: Thu Sep 24, 2009 7:41 am
by IJ.
Grab the data sheet here Andy
http://www.motec.com.au/filedownload.ph ... docid=1214
M800 pins crimp directly to the wire no need for heatshrink as it won't go into the weather seals on the plugs.
PostPosted: Thu Sep 24, 2009 9:34 am
by mr2andy
Thanks buddy... = )
PostPosted: Thu Sep 24, 2009 3:08 pm
by IJ.
Very welcome Andy!
It's a good idea to get the correct crimper for these pins as well as the hole in the body of the plug doesn't leave room for anything other than a nice roll crimp on the insulation.
They're a bit spendy but worth their weight in gold :)
PostPosted: Tue Sep 29, 2009 5:48 am
by mr2andy
Guy,
my problem is... by looking at the DEM adapter.. i don't know which pin is 1, 3, 4 and 5?
PostPosted: Tue Sep 29, 2009 8:10 am
by IJ.
mr2andy wrote:Guy,
They're marked pin #1 is the one with the red pin inserted :)
PostPosted: Tue Sep 29, 2009 8:46 am
by mr2andy
My bad.. I saw that when I took the part off the plastic package...
Thanks for the information bro..
Andy
PostPosted: Tue Sep 29, 2009 8:48 am
by IJ.
WHAT!!
I went out in the cold at 7am for nothing??? :D <jk>
No probs Andy!
